Which modifications the GDD IP data need to be imported in the IP Module?
Options
GDD IP data is not precisely as the IP data import require. And I´m not finding a clear description on the required format. I´d appreciate receiving an example of GDD IP data import into the IP module. Thanks for any help.
  • Hello Fabio, you may have already figured out your answer, otherwise here is a late response that may be of note for future reference.  GDD has modified the format slightly a couple of times, and we may not support all the variation.  I would suggest that you proceed to import GDD data using the standard OM ASCII import, then in the IP module run  "Import >Setup database for IP" to make sure you have all the necessary IP components  and can proceed with it as an IP database.
