Unable to export Master Layout
Once I have created a long section in the Master Layout I am trying to export as PDF. Unlike on previous Leapfrog Works versions I have used, there is no option/icon to export in the Master Layout or in the project tree. Am I missing something..?
The Section layout from the long section can only be exported from Sections object which is nested under the long section object in the tree.
The master Layout is only used to populate the nested sections within the long section. This is done to facilitate the Multiple Sections option in the long section set up.0
