Reverse polarity of a surface
KenIlodibe
Creating a model in Geo, used a surface as a lateral extent, however my inside/outside seems to be the wrong way. How do I change polarity of the surface?
The easiest way is to use the Swap Inside functionality on the lateral extent within your model.
Right-click on your lateral extent within the geological model / numeric model and choose to Swap Inside.
This will flip your polarity.
Let me know if you need any more help
- Bec0 -
Thank you!0
