How to deal with Invalid columns of resource report using EDGE
ISHEEGusuren
in Leapfrog
Hi guys,
Any idea to resolve the "Invalid" error when reporting a resource table for multi elements on EDGE? I recognize that this error is caused by the different number of blocks are assigned with grade interpolation.
Hi Ishee,
The Invalid status is usually referring to blocks with status of without_value. In this case it looks like by applying the cut-off for the Cu field, you still have blocks without a value for Ag, Pb and Zn. You will need to adjust the search neighbourhood or assign a value to those elements to get rid of the Invalid status.
Alternatively, creating a filter statement to filter blocks above a zero cut-off for each element would also work, however that then may exclude blocks from your main contributing elements in the reporting.
Cheers
Carrie1
