I need an alternative to the Geophysics levelling module for solving Block shifts visible in magdata
Options
PatrickWeeden
PatrickWeeden Posts: 1 Calcite Rank Badge
edited November 2020 in Oasis montaj
Is there an alternative module to the Geophysics Levelling Module in Geosoft that can be used to remove the visible block shifts in the grids.
If possible please provide a link to the the modules workflow.
Thank you.
  • GerryConnard1
    GerryConnard1 Posts: 6 Staff
    Depending on the nature of the issues, you may be able to use the "Grid Knitting" extension to solve you problems.
