Drill hole data directory paths
JamesLally
in Leapfrog
Is there any way to change the directory path for input files used for drillhole data? I'm using an external drive to swap between computers sometimes and I get different path assignments because of the local drives setup. If I want to refresh updated drillhole data from an ODBC link to an Access database I can only use the same drive letter designation that was set when I originally imported the data. Can a setting be changed anywhere to make the path relative to the Leapfrog model directory, or can the absolute path be changed?
James that's a tough spot to be in. I'm not sure about using relative paths for leapfrog. A potential workaround would be to use a dedicated cloud storage platform like Drive, Dropbox, or OneDrive for your models (or of course, Central). I've been using OneDrive (and Central) for my modeling needs and its been working great, even with large DEMs there has not been any performance issues.0
