Table of evaluated points on geologic volume
Options
In leapfrog works, does anyone have a solution to create a table of the points I've evaluated on a geologic solid? See image below - I'd like atable of the point names and attributes that are labeled "EXCAV" (green dots)
  • Hi Michael,
    If you evaluated the mesh solid as a GM onto the points, you can then export the points and include the evaluated column as part of the .csv export.
    I hope that helps.
    David
  • Thanks David, that worked.
    Also, I've learned creating a merged table from downhole data (how the points were derived) and the geologic model creates the same table.
