Font size
Options
Hi,
How do i change the deualts font size, for example in striplogs for the different data columns?
  • SaraDeschamps
    SaraDeschamps Posts: 7 Staff
    Hi Mathias,
    Where to look depends on which specific fonts you want to change, so i'll offer a few suggestions. You might want to look in the following areas of the Strip Log tool:
    • For the Hole name (Collar name) or Depth Tick labels, check the "Hole Trace" tab. Look for "Size (mm)".
    • For the Scale bars, or the numeric labels on the Data Strips themselves, click the "Define" button to open the "Parameters" dialog. Most of the font size options are found here. Look for "Text size (mm)".
    Hope this helps!
