Table of evaluated points on geologic volume
Options
MichaelDeVasto
in Leapfrog
In leapfrog works, does anyone have a solution to create a table of the points I've evaluated on a geologic solid? See image below - I'd like atable of the point names and attributes that are labeled "EXCAV" (green dots)
Hi Michael,
If you evaluated the mesh solid as a GM onto the points, you can then export the points and include the evaluated column as part of the .csv export.
I hope that helps.
David
1 -
Thanks David, that worked.
Also, I've learned creating a merged table from downhole data (how the points were derived) and the geologic model creates the same table.0
