Second problem with Extended Euler calculations in PDEPTH
Options
SlawomirPorzucek
in Oasis montaj
Hello,
First problem with Matlab libraries was resolved,
but I have second problem
The gx procedure calculates only for gravity data with more than 67 stations.
For 67 stations program crushed.
for les than 67 station I get information:
Maybe somebady met this problem.
Regards
Slawomir
Regards
Slawomir
Hi Slawomir,
Yes, this is a known issue that the underlying algorithm requires at least 67 samples. I'll log the need for a better error message & an update to the help.
Regards,
Tom0 -
Thank you Tom, I will try to use a special procedure to artificial increase a number of data
Regards
Slawomir0
