Second problem with Extended Euler calculations in PDEPTH
Options
Hello,
First problem with Matlab libraries was resolved,
but I have second problem :(
The gx procedure calculates only for gravity data with more than 67 stations.
For 67 stations program crushed.
for les than 67 station I get information:
Maybe somebady met this problem.
Regards
Slawomir
  • Hi Slawomir,
    Yes, this is a known issue that the underlying algorithm requires at least 67 samples. I'll log the need for a better error message & an update to the help.
    Regards,
    Tom
  • Thank you Tom, I will try to use a special procedure to artificial increase a number of data
    Regards
    Slawomir
