Get and change map object colormap to custom one through GX
DietmarKopp
DietmarKopp Posts: 10 Fluorite Rank Badge
Hi.
Since changing colormaps(for example for comparative profiles) is a chore in Geosoft, I am scripting a GX to do it.
Changing one colormap that is not in the standard folder and a zone file is about... 15 clicks? More?
Anyway.
Pretty much first GX.
I got a list of my maps and I filtered it for the ones I need
def rungx():
project = gxpj.Geosoft_project()
gxc = gx.GXpy()
gxpj.user_message("Maps","Maps: {}".format(project.project_maps))
mapnames=project.project_maps
IP_maps=filter(lambda x: 'IP_' in x, mapnames)
for map in IP_maps:
gxpj.user_message("Maps","Maps: {}".format(map))
with gxmap.Map.open(map) as gmap:
with gxview.View.open(gmap, "data") as v:
BUT I can't find anything in the documentation that allows me to get the grid and its colormap, nevertheless change it.
Sadly, the tutorial here
https://geosoftgxdev.atlassian.net/wiki/spaces/GXD93/pages/108528042/2D+Views+and+Maps
also says nothing about how to do a colormap
Any help?
  • With this code I have been able to get the maps loaded so far
    import geosoft.gxpy.gx as gx
    import geosoft.gxpy.map as gxmap
    import geosoft.gxpy.view as gxview
    import geosoft.gxpy.group as gxgroup
    import geosoft.gxpy.agg as gxagg
    import geosoft.gxpy.grid as gxgrd
    import geosoft.gxpy.viewer as gxviewer
    import geosoft.gxpy.project as gxpj
    import glob
    p_colormap=Geosoft\\Grids\\Profiles\\IP_bell.zon'
    filtterm='IP_'
    gxc = gx.GXpy()
    path='Geosoft\\'
    maplist=glob.glob(path+'*.map')
    IP_maps=filter(lambda x: filtterm in x, maplist)
    for maps in IP_maps:
    #print(maps)
    with gxmap.Map.open(maps) as gmap:
    with gxgroup.Color_map(cmap=p_colormap) as g:
    Here is where I don't know howto change the color map
