Export Tracklines as shp containing linegeometry
FredrikBrunback
in Oasis montaj
Hi.
I wonder if it is possible to export tracklines as lines for each database line in Oasis as shp?
When I export the tracklines using the map export I don't get any information such as line name.
When I export database as shp I get one shp for each database line but I get it as point format.
To clarify I wonder if I can get a single line shp for each database line.
Hi @NatalieGreen
Could you export linear shapefiles in Oasis ? (I need polylines)0 -
Thanks!
Do you know if this can be a new export function in the future ?
