GMSys 3D aeromagnetic data issue
I have an aeromagnetci data which was flown at 300 m height. The DEM data ranges from 373 to 2515 m. when I trying to use this data in GMSys 3D, I have to input the survey elevation at constant level above 2515, which is not real. I guess there is something missed, if some one help, will be highly appreciated.
  • PhilipSuttak
    PhilipSuttak Posts: 23 Staff
    Hello,
    When adding a magnetic survey there is an option to input your survey elevation from a grid, as seen in the screenshot of the dialog below. If your menu does not look the same, may I ask what version of Oasis Montaj you are using?
    Regards,
    Philip
    Product Manager
    Geosoft logo
