Radiometric software
EssamAboud
in Oasis montaj
I am looking for radiometric software within geosoft to process 1024 channel ground radiometric data. I know that OM has 256 channel software
http://www.geosoft.com/media/uploads/resources/brochures/OM_CRP_fs_2009_10_web.pdf
I tried it, it was for airborne only and also for 256 channel, varied from what I have.
is there any other tools within geosoft can work on this issue?
regards
Essam
regards
Essam
Hi @EssamAboud, You may be able to process 1024 channel radiometrics with Praga, have you looked at that?
http://www.geosoft.com/products/oasis-montaj/extensions/praga-radiometrics
I will try to find more info about dealing with ground radiometric surveys and check if it's possible to process with Praga.0
