Import data
AlesgerMammedov
in Oasis montaj
Good day.
I have proublem with import.
I export from Gemcom database data of collar.
Now i want import these data to target arcgis, but i can't.
I import csv file, then open the wizard window and below was writing 3 fields have been loaded as hole ID, I select holeid, locationx, locationy as hole id, easting and northing, but finish button switch off as still now.
And i don't know what is wrong. Can you help me please
Hi @AlesgerMammedov, the only thing I can think to do is to click on each of your database fields very carefully and double check that only your HoleID channel is set as the Hole ID channel type. Only the first two channel types, Not imported and Data, can be selected for multiple data fields. All others can have only a single Data field set as that channel type.
Another thing that might help is that if you look on the far right you will see some faint grey check boxes. These are the minimum requirements for that database type. So in the example below, to import collar data you have to have Hole ID, Easting, Northing, Elevation, and Total Depth. If one of these is missing you will not be able to import.
Community Manager0 -
Tnak you0
