Element thickness in Slope/W
It seems that I have a misunderstanding of the purpose of element thickness in geostudio 2024.2.1.
When I edit the element thickness at the geometry parent level in the "define projects", I assumed that it is referring to the thickness of the cross section drawn "into the page". I was thinking this would be useful where I wanted to, say, quickly evaluate a retaining wall's slope stability when a point load is applied in the middle of it.
This doesn't seem to have the effect I want, as element thickness does not change FoS results when a point load is applie on the retained soil.
Either I'm applying element thickness incorrectly, or I'm misinterpreting point loads? Are point loads really line loads going into the page, with a value of load/ft?
happy to send over a file, but it appears to be blocked in this forum
Any help would be much appreciated! Thank you!
