Hi, this is Joyjit from Perth. I’m working with 3D DXF polylines and meshes representing interpreted geological contacts. They were manually constructed in VULCAN and extended between holes to guide surface construction.
Has anyone extracted the corresponding contact points by intersecting these interpretations with drillhole trajectories reconstructed from collar and downhole survey data in Leapfrog? For polylines, I’m interested in how you handled cases where an interpretation comes close to a trajectory but does not intersect it exactly, and how you calculated the contact’s measured depth.
Can this workflow be done within Leapfrog Geo, or would you recommend an external tool such as Python? Any advice on a practical, repeatable approach would be appreciated.
