Hi Everyone,
Just wanted to share a quick tip for those newer to LeapFrog Geo around some options for downhole text display. This can be paricularly helpful when doing interp and analysis, or if you want to render an image from the active workspace instead of creating a full cross-section.
LeapFrog doesn't have a heapppp of flexibility in this area, so hopefully this can help someone wanting to see multiple assays, or a variety of their logs without constantly changing their display filter.
To display the data associated with each interval, click on the 'Show text' button (A) in the layers list. The default text to display will be what feature is currently visible; i.e. assay value, lithology, etc.
To change what text data is displayed, click the Format Display Text button:
If the default text format is active, the pop-up window will be empty. In here you can add the data fields you want to display downhole. You can add data in a list or stacked view, and can also input free text in this window.
A good way to view your formatting is to have a slicer view active when adding data to ensure the display is visually acceptable to you.
List view:
Stacked View (hit enter to move to a new line):
To format the colour of the text, clicking on the column in the label window will provide the option to apply a flat colour or an existing colourmap:
That's pretty much it! If you want to revert back to the default display, then simply delete everything within the label box.
Hope this tip was handy for some of you. Let us know if there's particular tasks you're having difficulty with and we'll try and help you find a solution.
Cheers!
