Mesh from points, filter by category
SamuelGilgen
You could look into using Guide Points, they are similar to how you would set up intrusions so would need both inside and outside categories.
The only way is forward!1 -
@SamuelGilgen How many different categories of points do you have that making queries doesn't work for you? What sort of data is this and what kind of meshes are you trying to model?
@JamesLally : The data set contains XYZ coordinates of different geologicial features (approx. 100 features: lithological boundaries, faults, shear zones) along a tunnel. The points (normally four points per feature) are constructed from a geological mapping during tunnel excavation. I would like to implicitly model meshes from these points - as simple as possible.
