import data?
SamandoulgouPatrick
Unconfirmed Posts: 2
hi all
can you help to understand why, the column type is not working to choose column type,
i would like to add more columns but it's not working.
below an image
Thank you
Are you trying to add in a new column to your Leapfrog drillhole data that you didn't import the first time? see the help file here:
you can't change a column type when you append or reload data.
okay, i see, much appreciated
i was trying to append or reload data by changing column type at the same time.
Perfect,
Thank you so much
- 304 Community
