Solid Validate
Hi All,
I have a question, how to validate a solid in the leapfrog geo, where the solid in *.dtm format.
Please you response.
Thankyou,
Regards
Hi Wisnuastaman,
When you import a .dxf (or a .dgn, .obj or the other 11 supported mesh formats) you get a pop-up window that gives you some options for clean-up and validation. The help section for mesh clean-up (and general importing help) is here: Meshes
After you import, if there are still issue with the mesh, Leapfrog will display them with icons on the mesh objects in the project tree. Picture below:
For more help on visualising errors in imported meshes, see this topic: Visualising Issues With Imported Meshes
If you have an open mesh, it is usually much easier to clean it up and fix it in the software that it was created.Regards, John
