Feature Request: Change UI font size or UI scaling
Can you add a setting to change the font size or UI scaling. I'd like to make things smaller in the Project Tree, Shape List, and Interval Selection lists so that I can see more things at once and do less scrolling.
Also, the Edit Colours button in the Shape List could be slimmed a bit. It's nearly double the width of everything else that appears in its column.
I'm using Leapfrog Geo 2024.1.3. If there's a better way to request features/improvements, please advise. Thanks for reading!
Hi Christian,
I'm afraid it isn't currently possible to change the font size on the project tree and shapelist or to change the size of each column in the shapelist.
One option that may help you is to put the shapelist into a different window and resize the windows so that Leapfrog and the project tree are next to each other on your screen. This may work better than putting the project tree to the right, as each row will take up less space.
We do have a feature request portal where we log all suggestions like this that come in. If you email support@seequent.com, we will be able to make sure we log all your suggestions, as well as getting an idea of your workflow and making sure we accurately document how it would be helped.
