Rock surface model, detect crossing with certain lithology
AndersBergumLauvli
Hi
I have created a rock surface model using "New mesh from offset points". The offset points are gathered from borehole data, at the soil-rock interface.
As it is only the boreholes that are drilled in rock that is included, some of the boreholes which is only drilled in soil is passing trough the rock surface model. Is it an automatic function in Leapfrog Works which can detect this, an add new points where the only-soil-boreholes is passing through the surface?
Hi @AndersBergumLauvli I just came across this post.. curious to know if this was figured out?
Hi @PrachiChitkara. No, I have not found a solution yet.
- 288 Community
