How to join two different geological models
JosedeJesusGomezEspi
I am using Deswik Mapping, and I want to export the contacts to create a small geological model; then, I want to join with the Main Geological Model to update it.
Hi Jesus, It depends, in a Vein, you can import the contacts as strings so they can be used as HW and FW. In a deposit you could make a new model from surface (a wireframe) and then add it to the main geological model as points or strings to redefine the boundary, you could also try it to do it directly (importing points or strings) and then add them to the main geological model without doing a small geological model
Hi @JosedeJesusGomezEspi
We have a blog on this workflow you might find helpful - https://www.seequent.com/an-underground-mapping-to-implicit-modelling-workflow/
