Why can 'Set Current X,Y,Z' (xyset.gx) change coordinate system?
VictorSavenije
in Oasis montaj
If a user wants to change projection, he/she can use setchprj.gx
Having xyset change a coordinate system is probably nearly always an undesired side affect.
Escalated this with sequent support with the request to add some documentation in the help menu of 'Set Current X,Y,Z' on how CRS works in gdb's channel based insetad of gdb-wide.
Thanks for the update, @VictorSavenije, and for raising this with the Seequent Support team. Adding documentation to clarify this behavior should help other users avoid confusion. Appreciate you keeping the community posted!
- 6 Community
- 15 Member Spotlight
- 40 Learning
- 2 Products
- 1 Geology
- 535 Leapfrog
- Geotechnical
- Geophysics
- 319 Oasis montaj
- 9 Res2DInv & Res3DInv
- 26 GX Developer
