download project from Central
Hi, how can I download a local copy of my Central project?
@WarrenCarter @TimLaneyrie1 @CarlosDelgado can you help with the steps?
Hi Angelina,
Any Central project that you open in Leapfrog is a local copy. Until you publish back to Central, any changes made to the project are only recorded in the local copy on your computer.
To download the project from Central, you must have Editor or Owner permission to the project in the Central Portal, and you must also have a Leapfrog Connector. When you open Leapfrog, click on the Central symbol in the top right corner and connect to your project. Then in the list under your Projects tab, find the Central project you want to download. Double click on it to bring up the project history tab. Select the revision of the project you want to download and either double click on it, or right click and choose Download. Once you have the copy downloaded, it will show up in the top of the page. Click on Open and Connect to begin working on it.
More info can be found here1
