How do you resample interval data in Leapfrog Geothermal?
Options
EdwardCharlesHakanso
in Leapfrog
I have some unevenly distributed interval data that I would like to see at 100 meter intervals. How can I do that in Leapfrog Geothermal?
You can use the New Numeric Upscale option under Upscaled Tables in the Wells folder. Choose Entire Well, then set your upscaling length in the dialog and in the Output Columns tab select the uneven data column you want to upscale.0
