what is the Difference between GSM_cs4 and GM in leapfrog?
Hello Everyone, I am AsmaParlin
Recently I am working with Leapgrog Geothermal.
I want to prepare a TOUFG2 model,
In leapfrog learning iguideline, they instracted to select "GM" foulder in the model to grid section and from another object section.
But,
instead of "GM" foulder If I select "GSM_cs4", is there any difference or any impact on TOUHG2 model?
  • [Deleted User]
    [Deleted User] Posts: 6 admin
    Hi @AsmaParlin, thank you for asking. I will have one of our experts pop in with an answer.
  • OliverWard
    OliverWard Posts: 1 mod
    Hi @AsmaParlin, if I understand correctly, you are asking what would happen to the TOUGH2 model if you selected a different GM (Geological Model). By selecting a GM you not only change the lithologies but you might also change the grid. Selecting a different GM will give you a different result. Does this answer your question?
