Edge - Extract Variable Orientation for a BM ?
Options
Is it possible to extract/export the variable orientation data used in an Edge estimate? That is, the dip, dip direction, pitch used at each block.
Hi @IainKelso, thanks for asking. I'll grab one of our experts to help you out. Stay tuned.
0 -
Hi Iain, yes you can export the variable orientations from the block model.
First evaluate the variable orientation object/s onto the block model. Then when exporting the block model, select the variable orientation object.
By default, the rotations are evaluated onto the parent block centroids. If you are using either the Octree or sub-block model, you can change it to sub-block centroids if you wish.
Near the bottom on the following link, it explains exporting the rotations:
https://help.seequent.com/Geo/2022.1/en-GB/Content/estimation/variable-orientations.htm?Highlight=variable%20orientation0
