Import DXF error
Options
I'm currently converting a project from one grid to another (NZMG - NZTM) and have an 'Import failed' msg. The same process I'm using works for polylines but not meshes.
Export - Convert in and save in QGIS - Re-import in LF
Does anyone know what's going on here?
  • Hey,
    Not sure about the type of data you're trying to import, but I've encountered this same problem recently and it was failing because I was trying to import it as a mesh and not as a polyline.
    I'd suggest trying importing as a polyline if it's not a solid object.
  • SeanBuchanan
    SeanBuchanan Posts: 17 mod
    Options
    Hi @ScottWillersDXF files cover a multitude of formats including polylines, points and DXF blocks. Do you know the source of the file, and for certain that it is a triangulation?
    I agree with @OyundalaiEnkhAmgalan . I would trying importing as a polyline. I suspect you're working with a string file.
