Can 3D polys and lines (for Cross sections) created in TFA be exported for use in Leapfrog
Options
JDGreybeck
in Oasis montaj
I have built cross sections in Target for ArcGIS.
Is there a way to export these data for import to Leapfrog?
hi @JDGreybeck if you export the section as a GeoTiff you will be able to import the sections as an image which should be correctly georeferenced in Leapfrog. This is the option you should use0
