Displaying output Volume (or closed mesh) by the thickness
Options
JamesChilomo
in Leapfrog
Is there a way I can display an output volume or closed mesh by thickness? can i also generate a (or how to generate an Isopach map)?
Hi James, I know that if this is a vein volume, the thickness parameter can be displayed in default in the shape menu (click on Lithology), but for an erosion or deposit it is unclear to me. If you find out please let me know, I am interested.
Thanks,0 -
After some research: You can display thickenss grids, but not thickness value on solid.
Follow the procedure here:
Thickness Grids (seequent.com)
