Creating a .gdb containing array channels
Options
JustinAnning
I'm using
in a stand alone python script. I can create a simple .gdb as per the tutorial example. Works very well thanks.
Now I'm trying to load data where I want to specify columns to load as an array channels. Do I still use the "write_line" function if I want to create a couple of array channels?
I've tried giving the same name for all the columns of data I want to load into the array channel as this seemed to what the reference below inferred, but it just loads up the first array value only. Am I on the right track?
Regards
Justin
geosoft.gxpy.gdb.write_line(line_name, data, header)
write_line
(line, data, channels=None, fid=(0.0, 1.0))Write data to a multiple channels in a line. If no channel list is provided it assumes that the data is for all channels from the line, the compliment of read_line().
Parameters: |
Regards
Justin
So to make a .gdb with both standard and array channels you can do this.....
import geosoft.gxpy as gxpy
import geosoft.gxpy.gdb as gxdb
lines = ['line1', 'line2', 'line3']
gxc = gxpy.gx.GXpy()
gdb = gxdb.Geosoft_gdb.new('test.gdb', overwrite=True)
for L in lines:
header = ['x', 'y']
data = [[1, 1, ],
[2, 2, ]]
header_array_z = 'z'
data_array_z = [[1, 2, 3, 4, 5, 6, 7, 8, 9],
[9, 8, 7, 6, 5, 4, 3, 2, 1]]
header_array_Vp = 'Vp'
data_array_Vp = [[1000, 2000, 3000, 4000, 5000, 6000, 7000, 8000, 9000],
[9000, 8000, 7000, 6000, 5000, 4000, 3000, 2000, 1000]]
line_name = gxdb.create_line_name(L, gxdb.LINE_TYPE_RANDOM, 0)
gdb.write_line(line_name, data_array_z, header_array_z)
gdb.write_line(line_name, data_array_Vp, header_array_Vp)
