copy Calculations and Filters to text
Options
RichardFlynn
RichardFlynn Posts: 6
edited February 2023 in Central
Can all calculations and filters be selected and copied to text?
  • RichardFlynn
    Options
    answered my own question by:
    Block Models export to 'CSV + Text File'
    Is there a better answer
  • RichardFlynn
    Options
    Actually, exporting the model to csv does not print the model items and model calculations to text.
    All the text file gives you is the model extents, block size, rotation...
  • DavidWatkins
    DavidWatkins Posts: 48 mod
    Options
    Hi Richard,
    Thanks for your feedback. I am adding it to an existing feature request to export and import Leapfrog calculations and filters in human readable text.
    Regards,
    David
  • andrewdalgliesh
    Options
    Hi David,
    Has there been any movement on this? I'm doing a lot of work between Edge projects and need to reference the calculations in each project without overwriting (i.e. export/import) the existing calcs, so exporting to text would be a life saver!
    Thanks
    Andrew
  • DavidWatkins
    Options
    Hi @andrewdalgliesh
    There is no movement on the feature yet, but I will log your upvote against the feature request.
    Thanks for the feedback.
    Regards,
    David
