Thickness Grid option not showing?
Options
NikolajHansen
in Leapfrog
As the title say. In some projects the opportunity to export thickness grids is not there when right clicking a mesh? Any tips?
Hi Nikolaj,
User-defined, editable meshes (the ones with mesh icon cog overlay) created inside of Leapfrog don't have the export thickness grid option. There is a work-around by extracting the mesh parts of your user-defined mesh to create a temporary static mesh, which can then be used to export a thickness grid.
I will however put in a feature request for you to add the export thickness grid menu option to user-defined meshes.
Regards,
David0
