copy Calculations and Filters to text
Options
RichardFlynn
Can all calculations and filters be selected and copied to text?
answered my own question by:
Block Models export to 'CSV + Text File'
Is there a better answer0 -
All the text file gives you is the model extents, block size, rotation...0 -
Hi Richard,
Thanks for your feedback. I am adding it to an existing feature request to export and import Leapfrog calculations and filters in human readable text.
Regards,
David0 -
Hi David,
Has there been any movement on this? I'm doing a lot of work between Edge projects and need to reference the calculations in each project without overwriting (i.e. export/import) the existing calcs, so exporting to text would be a life saver!
Thanks
Andrew2 -
Hi @andrewdalgliesh,
There is no movement on the feature yet, but I will log your upvote against the feature request.
Thanks for the feedback.
Regards,
David1
