GMSys 3D aeromagnetic data issue
Options
EssamAboud
in Oasis montaj
I have an aeromagnetci data which was flown at 300 m height. The DEM data ranges from 373 to 2515 m. when I trying to use this data in GMSys 3D, I have to input the survey elevation at constant level above 2515, which is not real. I guess there is something missed, if some one help, will be highly appreciated.
Hello,
When adding a magnetic survey there is an option to input your survey elevation from a grid, as seen in the screenshot of the dialog below. If your menu does not look the same, may I ask what version of Oasis Montaj you are using?
Regards,
Philip
Product Manager1 -
Hello Essam,
Further to Phillip's question above, we implemented support for variable elevation magnetic surveys in GM-SYS 3D in our version 8.5 release. So if you are using that version or later, you can honour the survey geometry by creating a survey elevation grid that incorporates the flight height. To do this, I would use grid math to add your flight height to the DEM grid to produce a survey elevation grid, as shown in the screen capture below. Then you can use the new grid as the survey elevation when adding the magnetic survey to GM-SYS 3D.
Best regards,
Darren Andrews
Technical Team Manager1
