Section scale adjustment
Options
AmitPatel
in Oasis montaj
Is there an option to view desired interval into section like striplog? Striplog has feature to view desired interval only on full map. Is it possible in section or fence diagram?
Hello Atanu,
You can display only a certain interval in a section plot by defining two variables in the Section Parameters dialog box. Under the Section Location tab, you can set the Ref Elevation (top extent) and the Vert extent (interval of the drillhole that you would like to display below the Ref Elevation).
Regards,
PhilipProduct Manager0 -
Hello,
I tried what you've suggested. Its a bit complicated as scale changes everytime as well as its trial and error type of thing. While striplog has better way of doing it. Can't this be done like many software that every hole in section be defined to display desired interval individually?0
