Automation of activities
GustavoXerez
GustavoXerez Posts: 1 Calcite Rank Badge
Dear colleagues,
I have been working in ANP - Brazil National Agency for Petroleum where we have some licenses of Geosoft Oasis Montaj.
It is my first time using the GX Developer API. Firstly, I need to automate some steps which are:
1. Read a gdb file
2. Delete channel(s)
3. Generate the X and Y channels by Latitude, Longitude and a current Datum
4. Create a Fiducial channel
5. Sort some channels
6. Export the modified data to the xyz format or asc format.
As I will develop the solution using C#, I looked into the gxnet\examples and gxnet\src directories in order to find examples to the implementation. As a result, I have found some samples which I am not certain if they will suit the solution. So, I put them bellow in accordance to the indexes above:
3. Directories CoordSysWizard\NewPCS and Database\SplitLinesOnXY
4. Directory Database \SplitLineAtFid
May you send me examples or just write me which ones I must study in order to achieve the solution? I need to develop the solution urgently.
I look forward to receiving an answer.
Thanks in advance!
Best regards,
Gustavo Xerez
  • Dear Gustavo.
    It seems like all of those tasks seem more suited to be solved by simply scripting your working steps, rather than programming a GX. Just an idea.
